customised location for remote alert handlers
when customising the location of (Linux) agent, the path a console looks to trigger a remote alert handler is not, also, customised. either within the agent setting or global settings, add parameter to specify path to remote alert handlers. alternatively, update the underlying code to automatically update the pathing, internally, when the agent is customised.
Comments: 1
Oldest
Newest
Most likes
Fewest likes
09 Apr
Andrea Vaccaro AdminHi Jeff,
thanks for your suggestion.
Could you please clarify the second part:
"alternatively, update the underlying code to automatically update the pathing, internally, when the agent is customised."
Thanks,
Andrea
