ALLNET IP Sensoric: Monitor bit inputs too
1 votes
We have been using the “ALLNET IP Sensoric Devices” integration for a long time. It works fine, but there is one thing missing: the integration of bit sensors. We use these to monitor the emergency power generator for malfunctions, for example. It would be great if bit sensors could also be integrated so that this type of data could also be monitored. Here is an example:
<sensor108>
<name>Power generator malfunction</name>
<value_float>0.00</value_float>
<value_int>0</value_int>
<value_string>0.00</value_string>
<min_abs_float>0.00</min_abs_float>
<max_abs_float>1.00</max_abs_float>
<min_day_float>0.00</min_day_float>
<max_day_float>1.00</max_day_float>
<value_display>0.00</value_display>
</sensor108>
Under consideration Checks&Agents Suggested by: Malte Upvoted: 12 Feb Comments: 0
Comments: 0
