Add cmk-agent-ctl.exe and check_mk_agent.exe to PATH environment Variables on Windows
It would be cool if, after installing the agent, the most frequently used tools were available everywhere in the console via an environment variable
Comments: 1
14 Mar
Mohamed Saleh AdminHi Felix,
Thank you for posting on our Ideas Portal!
The idea description clearly states a solution, but we are missing the context around your use case or what problem you are facing which this feature would help you to solve? Having this context will help other users with similar problems to comment and vote on the idea, and it is important for us when doing discovery and analysis on the ideas.
Looking forward to hearing from you!
