cmcdump - Web UI
Allow CMC Dump to be executed from the Web UI in a way that we could perform the following actions from the Web UI:
Generate configuration and monitoring files manually with a download button
Allow the execution of a schedule
Allow the usage of S3 or Azure Storage to store the files
Allow the receival of data using API
Allow the deployment of a monitoring server in a private network sending the CMCDump data to Checkmk SaaS
Benefits:
Will reduce the need to use SSH connection to the server
Will simplify the usage of CMCDump
Will allow this feature to be used with Checkmk Saas to consolidate data to be consumed by other Saas solutions like Grafana Cloud
We are working in a usecase to expose data from our environment on a Checkmk Server hosted externally reading data generated using cmcdump and providing it to Saas solutions.
