mk-sql: add option to exlcude Backups for Offline Databases
17 votes
The new Check for sql Server has many Options to disable several sections, but I am missing an option to exclude SQL Backups for Databases which are "Offline". As doing an Backup in SQL Server is not working, they won`t get a new Backup Date and I would expect some option to remove them from plugin output. At pluginlevel the plugin show now the corresponding database for each backup and should be able to get informations about the state.
Under consideration Checks&Agents Suggested by: Andreas Hoffmann Upvoted: 07 Jan Comments: 1
Comments: 1
