WATO: Input fields for RegExp and TextInput should be visually distinguishable
18 votes
In the WATO plugins it is currently not possible to recognise whether a certain input field accepts only regular text or a regular expression. The fields look identical and you have to switch on the inline help to see which is which. I would appreciate if one of them had a small icon or similar next to it.
As a first test I wrote a subclass of RegExp which adds such an icon. What do you think?
Under consideration Usability Suggested by: Dirk Upvoted: 25 Mar Comments: 0
Comments: 0
