Business intelligence: Removing of Rules with dependencies
13 votes
When deleting BI Rules, you have to delete the top level rule first, then the lower hierarchy rules.
If you have a lot of "verschachtelte" rules then this is a messy work :-)
As well if you mark both rules (top and lower hierarchy ones) the deletion of those does not work at all.
I would like to mark all rules (with dependencies) and delete them in one click.
It would be even okay if the system checks if the rule marked for deletion is dependent on another, and if the other rule is also marked for deletion - then delete them both.
Otherwise, just delete the top rule and push an information.
Under consideration Rules Suggested by: Constantin Lotz Upvoted: 21 Oct, '23 Comments: 5
Comments: 5
OldestNewestMost likesFewest likes
