Business Intelligence: Extend the options for "aggregation functions"
Currently, the option "aggregation functions" provide three different options to handle the states in a child node:
* Sort from best to worst and take the n-th entry as state for the child node
* Sort from worst to best and take the n-th entry as state for the child node
* Set the child node state by the amount of OK states of its entries.
This may not be sufficient in all scenarios and needs to be extended.
Please leave examples in the comments, so tribe29 gets an idea of all the different use cases, that need to be considered.
Comments: 6
Oldest
Newest
Most likes
Fewest likes
26 Sep, '22
MathiasThe option "amount of OK States" should be the exact number but if set to 1 it also accepts 2 OK nodes. With this option for defining the exact number we could check if there is only one "Primary" which was and could the case in Postgresql for example.
You could also think about to set operands dynamically like choose between XOR, OR, AND, ... -
05 Nov, '22
Mathias MergedAdd BI rule to match "Count exact number of OK nodes". At the moment a rule counts "minimum number of OK nodes".
18 Oct, '23
Martin Hirschvogel AdminHello,
Thank you for your idea. On this portal, we carefully evaluate ideas to ensure that they will benefit a wide range of users. Thus, we close ideas not fulfilling certain criteria:
- Suggestions with low user interest: created more than 1 year ago with 5 votes or less
- Suggestions with no momentum: no votes in the last 6 months
Unfortunately, this suggestion doesn't meet these criteria, so we’re closing it (based on the data available until 2023-10-17). We appreciate your contribution and encourage you to continue to share your ideas. Your input plays a vital role in helping us improve our product for everyone.
Thank you for your understanding and continued support!
Warm regards,
Your Checkmk Team -
18 Oct, '23
Marcel Arentz Admin MergedHello,
Warm regards,
Your Checkmk Team -
03 Nov, '25
Sebastian Krahe System"More BI aggregation functions" (suggested by <Hidden> on 2022-11-05), including upvotes (13) and comments (1), was merged into this suggestion.
